This Product Selection Guide contains information to help select products in the Clock Generators, PLLs, Frequency Synthesizers category on DigiKey.com
Clock generators, PLLs, and frequency synthesizer integrated circuits (ICs) provide a steady timing pulse from a reference signal for logic devices such as computers, microcontrollers, data communication systems, and graphic/video generators. These integrated circuits may include buffers, drivers, dividers, multipliers, multiplexers, synthesizers, fanout distributors, and prescalers.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or configuration variables prior to shipping. For unverified products, please inquire with ProgCent.Techs@digikey.com
Type: Describes main function or usage of the circuit.
PLL: Indicates whether or not a device incorporates a phase-locked loop function.
Input: Enumerates the supported formats for clock/timing signals input to a device.
Output: Indicates the type of electrical signal the device provides, such as CMOS, differential, or TTL.
Number of Circuits: Indicates the number of circuits of similar function that are implemented within the device.
Ratio - Input:Output: Indicates the number of signal inputs and outputs present in each functional circuit within a device.
Differential - Input:Output: Indicates if the clock signal inputs/outputs of a device employ or allow use of a differential signalling scheme.
Frequency - Max: Describes a device’s maximum operating frequency; the max rate at which an input power source is switched in the course of the conversion process.
Divider/Multiplier: Indicates presence of a divider or multiplier function on the device.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Package / Case: Indicates the type of protective case used on an electronic component to allow easy handling, installation, and protection. This selection was determined to be the closest industry standard applicable to the suppliers device packaging. Typically it is best to check the actual dimensions from the datasheet rather than depend on this terminology when designing your circuit.
ProductExamples
16-DIP Phase Lock Loop (PLL)
| MFR PART # | CD4046BEE4 |
| DIGIKEY PART # | 296-36086-5-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | IC PHASE-LOCK LOOP MCPWR 16-DIP |
32-VFQFN Exposed Pad Clock Generator
| MFR PART # | CDCM61002RHBR |
| DIGIKEY PART # | 296-31623-1-ND |
| DESCRIPTION | IC CLK GEN 1:2 LOW JITTER 32QFN |
MediaLinks
Videos
PCI Express (PCIe) Clock Generators by IDT
Clock
Articles
Minimizing Jitter/Phase Noise in Clock-Distribution Topology is Critical to Wireless Performance
Clock
Product Training Modules
Si533x/5x Any-Rate Clock Generators and Clock Buffers
Clock
TechForum
Clock
