This Product Selection Guide contains information to help select products in the Labels, Stickers, Decals - Blank category on DigiKey.com
Blank Labels, Stickers, and Decals are materials (Aluminum, Cardboard, Cloth, Fabric, Nylon, Paper, and many more) with a sticky backing.
SelectionCharacteristics
Label Type: Indicates physical attributes or characteristics of a product.
Printer Name: Indicates the name(s) of compatible printers for the part.
Applications: Defines the use case for the part.
Color - Background: Indicates the color(s) that will be printed on.
Length: Indicates the overall length of the label.
Width: Indicates the overall width of the label.
Diameter - Label: Indicates the overall diameter of the label.
Location: Indicates if the label is designed for indoor or outdoor environments.
Material - Body: Indicates the material used for the label.
Material: Indicates the material used for the label.
Label Size: Indicates the overall dimensions for the part.
ProductExamples
| MFR PART # | TAG15T3-795 |
| DIGIKEY PART # | 1436-1838-ND |
| MANUFACTURER | HellermannTyton |
| DESCRIPTION | METALIZED POLYESTER 1X.5" |
| MFR PART # | M21-500-414 |
| DIGIKEY PART # | 2267-M21-500-414-ND |
| MANUFACTURER | Brady Corporation |
| DESCRIPTION | BRADYGRIP PRINT-ON HOOK MATERIAL |
