This Product Selection Guide contains information to help select products in the Labels, Labeling category on DigiKey.com
Items in this family are materials and products used for marking or labeling wires, circuit breakers, switches, etc. They range from bulk materials such as heat shrinkable tubing that can be written on prior to application, to rolls of pre-cut labels of uniform size designed for use with a specific manufacturer’s printing equipment. Similar items with pre-printed letters, characters, or other information are not included.
SelectionCharacteristics
Label Type: Indicates physical attributes or characteristics of a product.
Label Size: The physical dimensions of the label, given in a variety of patterns dependent on the shape and attachment method of the label. Dimensions are given in Inches (Millimeters).
Color: The dominant color of the label.
Material: Indicates the material composition of the label.
Shelf Life: The manufacturer’s specified shelf life for the product. Shelf life begins from date of manufacture.
ProductExamples
| MFR PART # | S100X150YAJ |
| DIGIKEY PART # | 298-10681-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | White Self Laminating Label 1.00" x 1.50" (25.4mm x 38.1mm) |
| MFR PART # | B33-94-2-342 |
| DIGIKEY PART # | 2267-B33-94-2-342-ND |
| MANUFACTURER | Brady Corporation |
| DESCRIPTION | White Heat Shrinkable Label 2.00" W x 0.09" Dia (50.8mm x 2.4mm); Cable O.D. 0.02" ~ 0.08" (0.6mm ~ 2.0mm) |
| MFR PART # | TAG63L-105 |
| DIGIKEY PART # | 1436-1676-ND |
| MANUFACTURER | HellermannTyton |
| DESCRIPTION | White Self Laminating Label 1.00" x 1.33" (25.4mm x 33.8mm) |
| MFR PART # | TMS-SCE-1/4-2.0-4 |
| DIGIKEY PART # | TMS-SCE-1/4-2.0-4CT-ND - Cut Tape (CT) |
| MANUFACTURER | TE Connectivity Raychem Cable Protection |
| DESCRIPTION | Yellow Heat Shrinkable Label 0.25" x 1.97" (6.4mm x 50.0mm) |
MediaLinks
Videos
Applying Turn-Tell™Labels
