This Product Selection Guide contains information to help select products in the Tags category on DigiKey.com
Tags are a piece, strip, or formed paper, plastic, aluminum, polyester, or vinyl used to attach one end to an electrical box, machine, wire, switch, or person to let an individual know where, who, or what is being done.
SelectionCharacteristics
Color: Defines the colors used for the tag.
Material: Indicates the material used for the tag.
Label Type: Defines the use case for the tag.
Label Size: The physical dimensions of the tags. Typically length X width.
ProductExamples
| MFR PART # | 65448 |
| DIGI-KEY PART # | 2267-65448-ND |
| MANUFACTURER | Brady Corporation |
| DESCRIPTION | B853 5.75HX3 BK/RD/WH L/O REV.F, |
| MFR PART # | 4036-B |
| DIGI-KEY PART # | 2267-4036-B-ND |
| DESCRIPTION | 4036-B CONDENSATE DRAIN/YEL/STY |
