This Product Selection Guide contains information to help select products in the Signs, Nameplates, Posters category on DigiKey.com
Signs, Nameplates, and Posters are things suggesting, giving guidance, advertising, or stating information to be used inside or outside to provide important information. The filters are characterized by color, for use with/related products, material, label type, and label size. The for use with/related products include danger, lead free – RoHS, lock out, ratings, static sensitive, voltage, or warning.
SelectionCharacteristics
Color: The dominant color(s) of the product.
Material: Indicates the material composition of the product.
Label Type: Indicates the printed message that is on the product.
Label Size: The physical dimensions of the device. Typically length X width.
ProductExamples
| MFR PART # | 144387 |
| DIGIKEY PART # | 2267-144387-ND |
| MANUFACTURER | Brady Corporation |
| DESCRIPTION | B555 7X10 ANSI BLK,YEL,RED/WHT H |
| MFR PART # | 141941 |
| DIGIKEY PART # | 2267-141941-ND |
| DESCRIPTION | B555 10X7 BLK,RED/WT NO SMOKING |
| MFR PART # | 1485-00071 |
| DIGIKEY PART # | 3900-1485-00071-ND |
| MANUFACTURER | TAPCO |
| DESCRIPTION | SAFE PACE 100,11" RADAR FEEDBACK |
