This Product Selection Guide contains information to help select products in the Video Cables (DVI, HDMI) category on DigiKey.com
Video Cables (DVI, HDMI) have interconnects on one or both ends of the cable. These devices are often used for connecting to or between video sources. The characters are connector type, length, cable type, shielding, and usage. The usages are CCD camera, digital visual interface, high definition multimedia interface, multi media, patch, and Raspberry Pi.
SelectionCharacteristics
1st Connector Type: Indicates the style and configuration of the first connector used on the cable assembly.
2nd Connector Type: Indicates the style and configuration of the second connector used on the cable assembly.
Length: The length of the cable assembly, this length may or may not include the connectors. Please consult the individual datasheets.
1st Connector Mounting Type: Indicates how the first connector of the cable assembly is attached.
2nd Connector Mounting Type: Indicates how the second connector of the cable assembly is attached.
Cable Type: Indicates the physical form or structure of the cable.
Color: The dominant color of the cable assembly.
Shielding: Whether or not the device possesses an electrically insulating barrier that helps to reduce or eliminate electromagnetic interference.
Usage: The typical expected usage the manufacturer designed the cable assembly for.
ProductExamples
| MFR PART # | P569-001 |
| DIGIKEY PART # | TL1665-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | Cable Assembly 1.00’ (304.80mm) |
| MFR PART # | 1321027-10 |
| DIGIKEY PART # | Q389-ND |
| MANUFACTURER | Qualtek |
| DESCRIPTION | Cable Assembly 10.0’ (3.05m) |
| MFR PART # | 741-20010-00500 |
| DIGIKEY PART # | 1175-1164-ND |
| MANUFACTURER | CNC Tech |
| DESCRIPTION | Cable Assembly 16.4’ (5.00m) |
| MFR PART # | 978 |
| DIGIKEY PART # | 1528-1575-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | Cable Assembly 1.31’ (400.00mm) |
MediaLinks
TechForum
DVI Differences
HDCP and HDMI What, Why and How
