DVI Differences
Looking at this I realized that some might have problems identifying which connector is which. I provided the information below to expound on the explanation.
For the first two variations above there are actually two more variations as there is a single link and a dual link version.
As one might expect, single-link DVI is the slower, less capable version as it only supports up to a 60 Hz refresh rate with 1920 x 1200 resolution while dual-link DVI supports up to 2560 x 1600 at 60 Hz resolution.
You can identify the connector you need by matching the pins below.
DVI - Integrated Dual Link
DVI - Integrated Single Link
DVI - Digital Dual Link
DVI - Digital Single Link
DVI - Analog
You can find suitable options for DVI cables and more at the links below.
Product Index > Cable Assemblies > Video Cables (DVI, HDMI)
