This Product Selection Guide contains information to help select products in the USB, DVI, HDMI Connector Adapters category on DigiKey.com
USB, DVI, HDMI Adapters are used to convert from one USB, DVI, HDMI connector style to another style, whether they are Board mounted, DIN Rail, Free Hanging, Panel Mount, or PCB mounted. Examples include Digital Flat Panel, DisplayPort, DVI-I, Firewire, HDMI, Magnetic Rectangular connector, Rectangular connector, Terminal Blocks, and USB plug or receptacle.
SelectionCharacteristics
Convert From (Adapter End): Indicates the style and configuration of the connector being converted from.
Convert To (Adapter End): Indicates the style and configuration of the connector being converted to.
ProductExamples
| MFR PART # | 1018840000 |
| DIGIKEY PART # | 281-3465-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | Adapter Connector USB-A (USB TYPE-A), Receptacle To USB-A (USB TYPE-A), Receptacle Panel Mount |
| MFR PART # | 1005-1092-WH |
| DIGIKEY PART # | 1175-2084-ND |
| MANUFACTURER | CNC Tech |
| DESCRIPTION | Adapter Connector USB - Micro B, Receptacle To USB-C (USB TYPE-C), Plug Free Hanging (In-Line) |
| MFR PART # | SCRU-02 |
| DIGIKEY PART # | SAM8637-ND |
| MANUFACTURER | Samtec Inc. |
| DESCRIPTION | Adapter Connector USB-B (USB TYPE-B), Receptacle To USB-A (USB TYPE-A), Receptacle Panel Mount, Bulkhead |
| MFR PART # | UR024-000-RA |
| DIGIKEY PART # | TL1778-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | Adapter Connector USB-A (USB TYPE-A), Receptacle To USB-A (USB TYPE-A), Plug Free Hanging (In-Line), Right Angle |
| MFR PART # | EHUSBABX |
| DIGIKEY PART # | SC2060-ND |
| MANUFACTURER | Switchcraft Inc. |
| DESCRIPTION | Adapter Connector USB-A (USB TYPE-A), Receptacle To USB-B (USB TYPE-B), Receptacle Panel Mount |
