This Product Selection Guide contains information to help select products in the USB, DVI, HDMI Connector Accessories category on DigiKey.com
Accessories for USB, DVI, and HDMI connectors are supplementary/accessory items like blockout device, boot, contact assembly, cover, ferrule, gasket, ground terminal, hardware, hex head screw, hood, housing, inner shell, jackscrew, latch, mounting frame, pull bar, screening can, seal, shell kit, shield, shielding plate, thumb screw, and wire guide.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # | CP-USB-B |
| DIGIKEY PART # | RP782-ND |
| MANUFACTURER | Essentra Components |
| DESCRIPTION | Connector Cover, Dust For USB-B (USB TYPE-B) |
| MFR PART # | MUSB-2A111-024BP |
| DIGIKEY PART # | MUSB-2A111-024BP-ND |
| MANUFACTURER | Amphenol ICC (Commercial Products) |
| DESCRIPTION | Connector Cover, Dust For USB-A (USB TYPE-A) |
| MFR PART # | DCA-17-01 |
| DIGIKEY PART # | SAM8760-ND |
| MANUFACTURER | Samtec Inc. |
| DESCRIPTION | Connector Cover, Dust For SCPU Series |
| MFR PART # | 3E306-3200-008 |
| DIGIKEY PART # | 3M9421-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Connector Shell Kit For Firewire (IEEE 1394) Receptacles |
