This Product Selection Guide contains information to help select products in the Cable Assemblies - KIT category on DigiKey.com
Cable assemblies are a length of electrical or fiber optic cable material terminated with some type of connector or contact at one or both ends. These include finished-goods products such as standard USB, DVI, and HDMI cables, extension cords for AC utility power, network cables, and replacement power cords for appliances and consumer electronics. Partial assemblies designed for incorporation into other products are included, such as pre-crimped leads for a variety of common connector styles.
SelectionCharacteristics
Kit Type: A general description of the function and contents of the kit.
Values: Indicates the number and/or type of items the kit contains.
ProductExamples
| MFR PART # | 743 |
| DIGIKEY PART # | 1528-2000-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | Cable 2 pc - 2.1mm ID, 5.5 mm OD, Barrel Jack to Wire Leads, Barrel Plug to Wire Leads, 178mm |
| MFR PART # | PRT-10361 |
| DIGIKEY PART # | 1568-1500-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | Cable |
| MFR PART # | KHFC3-086+ |
| DIGIKEY PART # | 3157-KHFC3-086±ND |
| MANUFACTURER | Mini-Circuits |
| DESCRIPTION | Cable Test Leads 25 pc - 25 ea SMA to SMA |
