This Product Selection Guide contains information to help select products in the Terminal Block Adapters category on DigiKey.com
Terminal block adapters are used to convert to or from a terminal block connector. The terminal block side comes in a selection of different position and row combinations. The type of connectors being adapted to include: card edge, D-sub, quick connects, rectangular, solder tabs, and other terminal blocks. They are available in a variety of wire gauges from 30 AWG to 8 AWG.
SelectionCharacteristics
Convert From (Adapter End): Indicates the style and configuration of the device being converted from.
Convert To (Adapter End): Indicates the style and configuration of the device being converted to.
Wire Gauge: The wire size or size range with which a product is designed for use, typically expressed in terms of AWG (American Wire Gauge).
ProductExamples
| MFR PART # | 9915480000 |
| DIGIKEY PART # | 281-1560-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | Adapter Terminal Blocks, Screw Connection, 6 Pos, 2 Rows To NEMA 5-15R |
| MFR PART # | 2280284 |
| DIGIKEY PART # | 277-5051-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Adapter Terminal Blocks, Screw Connection, 50 Pos, 2 Rows To Rectangular Connector, Male Pins, 50 Pos, 2 Rows |
| MFR PART # | 776990-01 |
| DIGIKEY PART # | 2770-776990-01-ND |
| MANUFACTURER | NI |
| DESCRIPTION | Adapter Terminal Blocks, Screw Connection, 100 Pos, 5 Rows To D-Sub, 100 Pos, 2 Rows |
| MFR PART # | DCN4-TB4 |
| DIGIKEY PART # | Z9087-ND |
| MANUFACTURER | Omron Automation and Safety |
| DESCRIPTION | Adapter Terminal Blocks, Screw Connection To |
