This Product Selection Guide contains information to help select products in the Memory Card Readers category on DigiKey.com
Memory Card Readers are an input and output device that is designed to accept one or more of several standardized versions of flash-based storage cards. The card types are CF, MS, SD, micro SD, micro M2, SM, SDHC, MS Duo, MMC, RS-MMC, micro SDHC, mini SD, SK, XD, HS MS, MS Pro, and MS Pro Duo.
SelectionCharacteristics
Card Type: Indicates the industry standard memory card format(s) with which a product is designed for use.
ProductExamples
| MFR PART # | U352-000-MD-AL |
| DIGIKEY PART # | TL2309-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | SUPERSPEED MULTI-DRIVE MEMORY CA |
| MFR PART # | COM-13004 |
| DIGIKEY PART # | 1568-1414-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | MICROSD USB READER |
| MFR PART # | SCE2MSDB76A121SN |
| DIGIKEY PART # | 623-SCE2MSDB76A121SN-ND |
| MANUFACTURER | Amphenol Limited |
| DESCRIPTION | MICRO-SD CARD READER BRASS, BLAC |
| MFR PART # | 939 |
| DIGIKEY PART # | 1528-2582-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | USB MICROSD CARD READER/WRITER - |
