This Product Selection Guide contains information to help select products in the Memory - Modules category on DigiKey.com
Products within the memory module family are solid-state data storage devices with standardized physical module formats for use in common computer equipment, single board computers, and similar devices capable of accepting standardized memory modules. Devices based on both non-volatile (flash, NVRAM) and volatile (SDRAM) memory technologies are included.
SelectionCharacteristics
Memory Type: The specific type or technology of memory used in the module.
Memory Size: The total amount of data storage capacity provided.
Transfer Rate (Mb/s, MT/s, MHz): The speed at which data can be read from or written to the module.
MFR PART # | MT8KTF51264HZ-1G9P1 |
DIGI-KEY PART # | 557-1767-ND |
MANUFACTURER | Micron Technology Inc. |
DESCRIPTION | Memory Module DDR3L SDRAM 4GB 204-SODIMM |
DATASHEET | Click Here |
MFR PART # | SFUI008GJ1AE1TO-I-5S-2AP-STD |
DIGI-KEY PART # | 1052-SFUI008GJ1AE1TO-I-5S-2AP-STD-ND |
MANUFACTURER | Swissbit |
DESCRIPTION | Memory Module 8GB Module |
MFR PART # | M408TQJGR-RA000-D |
DIGI-KEY PART # | 3247-M408TQJGR-RA000-D-ND |
MANUFACTURER | Delkin Devices, Inc. |
DESCRIPTION | Memory Module FLASH - NAND (SLC) 8GB Module |
MediaLinks
Product Training Modules
XR-DIMM DRAM Module Solutions - Apacer
High Density Solutions - Viking Technology
DRAM Module Testing - Viking Tech
