This Product Selection Guide contains information to help select products in the Specialized category on DigiKey.com
Devices designed to provide a specific function in specialized situations.
SelectionCharacteristics
Applications: Application is the type of equipment or environment the device will be used in, they are tested and typically rated by a third party to ensure certain minimum standards for the application they are intended for. You could use one with a higher rating, but you cannot use one with a lower rating as it will fail in that application. For example, you could use a medically rated device to replace a commercial device, but you cannot replace the medical device with the commercial device.
Memory Type: The specific type or technology of memory used.
Memory Size: The total amount of data storage capacity provided.
MFR PART # | DS1925L-F5# |
DIGI-KEY PART # | DS1925L-F5#-ND |
MANUFACTURER | Analog Devices Inc./Maxim Integrated |
DESCRIPTION | Memory Card |
DATASHEET | Click Here |
MFR PART # | DS9092K# |
DIGI-KEY PART # | DS9092K#-ND |
MFR PART # | DS1985-F3+ |
DIGI-KEY PART # | DS1985-F3±ND |
DESCRIPTION | Memory Card EPROM 2KB |
