This Product Selection Guide contains information to help select products in the Spacers, Standoffs category on DigiKey.com
LED spacers and standoffs are cast or extruded plastic devices that provide electrical insulation, alignment, and support for through-hole LEDs that are mounted above standard board height. They are designed for specific LED sizes, shapes, and configurations, and of materials such as EPDM, polymer, Nylon, polycarbonate, propylene, and PVC. Common colors are white, black, and natural.
SelectionCharacteristics
Color: The dominant color of the device.
Length: Indicates the length of the standoff.
LED: Indicates the size or standard form factor of LED a spacer/standoff is designed to accommodate.
Material: Indicates the material composition of the device.
ProductExamples
| MFR PART # | ELM 2-250 |
| DIGIKEY PART # | 492-1856-ND |
| MANUFACTURER | Bivar Inc. |
| DESCRIPTION | LED MNT SELF RETAINING T-1 0.25 |
| MFR PART # | 7363 |
| DIGIKEY PART # | 36-7363-ND |
| MANUFACTURER | Keystone Electronics |
| DESCRIPTION | SPACER MOUNTS LED T-1 .340" |
| MFR PART # | H-101C-1 |
| DIGIKEY PART # | 492-2502-ND |
| DESCRIPTION | LED HOLDER RA 3MM 2LD NYL BK |
