This Product Selection Guide contains information to help select products in the Component Insulators, Mounts, Spacers category on DigiKey.com
Products in this family are formed from electrically insulative materials and are used for positioning, retention, or mechanical spacing of components. Products in TO-5 metal can packaging, for example, are at risk of creating unintended connections on a printed circuit board through inadvertent contact of the device’s case with an inappropriate node in the circuit; placement of an appropriate insulator beneath the device when mounting it reduces this risk.
SelectionCharacteristics
Type: Defines if the part is an insulator, mount, or spacer.
Shape: Defines the shape of the part.
Usage: Indicates the type of component the part is designed to insulate.
Material: Indicates the material composition of the device.
Color: What color the part is.
Features: Special performance characteristics built into the part.
Length: The overall length of the part.
Width: The overall width of the part.
Height: The overall height of the part.
Diameter - Outside: The overall outside diameter for the part.
Diameter - Inside: The overall inside diameter for the part.
ProductExamples
| MFR PART # | 109-045 |
| DIGIKEY PART # | 492-1483-ND |
| MANUFACTURER | Bivar Inc. |
| DESCRIPTION | MOUNT CIRCULAR TO18 0.045" |
| MFR PART # | IEC-TO-220-18 |
| DIGIKEY PART # | RPC1744-ND |
| MANUFACTURER | Essentra Components |
| DESCRIPTION | INSULATOR RECT TO220 0.140" |
| MFR PART # | V4555 |
| DIGIKEY PART # | AE10875-ND |
| MANUFACTURER | Assmann WSW Components |
| DESCRIPTION | SPACER CIRCULAR GEN PURP 2.5MM |
