This Product Selection Guide contains information to help select products in the UARTs (Universal Asynchronous Receiver Transmitter) category on DigiKey.com
UARTs (Universal Asynchronous Receiver/Transmitter) interfaces are physical circuits that convert parallel bits from a microcontroller or CPU into serial bits for transmission or convert received serial bits to parallel bits for use by another microcontroller or CPU. UARTs may use RS232, RS422 or RS485 protocols for data transmission and are selected by number of channels, data rate and additional features such as internal oscillators, timer, counter, GPIO and printer ports.
SelectionCharacteristics
Features: These are different capabilities or properties of the device such as configurable GPIO or a printer port.
Number of Channels: Indicates how many individual outputs this device provides.
FIFO’s: Indicates the size of on-chip data buffer memory.
Protocol: Enumerates the communications protocols and/or standard interfaces that a device supports or implements.
Data Rate (Max): Characterizes the maximum rate at which information can be transmitted or received by a device. Does not necessarily refer to throughput rate for user data, see device datasheets for further information.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
With Auto Flow Control: Indicates if a device includes features for automatically managing data transmission to avoid loss due to buffering errors.
With IrDA Encoder/Decoder: Indicates if a device includes features for optical communications, per specification established by the Infrared Data Association.
With False Start Bit Detection: Indicates if a device includes features for discriminating between valid start bits and noise transients on its receive channel(s).
With Modem Control: Indicates if a device includes features used for interfacing with a modem.
ProductExamples
| MFR PART # | ST16C550CJ44-F |
| DIGIKEY PART # | 1016-1259-5-ND |
| MANUFACTURER | MaxLinear, Inc. |
| DESCRIPTION | UART IC 1, UART Channel 16 Byte 44-PLCC (16.59x16.59) |
| MFR PART # | MAX3109ETJ+T |
| DIGIKEY PART # | MAX3109ETJ+TTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | UART IC 2, DUART Channel RS232, RS485 128 Byte 32-TQFN (5x5) |
| MFR PART # | SC16IS741AIPWJ |
| DIGIKEY PART # | 568-10959-2-ND - Tape & Reel (TR) |
| MANUFACTURER | NXP USA Inc. |
| DESCRIPTION | UART IC 1, UART Channel RS232, RS485 64 Byte 16-TSSOP |
| MFR PART # | ID82C52 |
| DIGIKEY PART # | ID82C52-ND |
| MANUFACTURER | Renesas Electronics America Inc |
| DESCRIPTION | UART IC 1, UART Channel RS232 28-CerDip |
MediaLinks
Videos
XRUSB1 software driver simplifies legacy COM port support for USB UARTs in Windows
Sparkfun Apollo3 Blue Dev Board
Analog Devices IO-Link Transceivers
Articles
Microcontrollers - Need for UARTS Grows
UARTs Provide Reliable Serial Communication
The Ins and Outs of Standard Interfaces
More Articles on UARTs
Product Training Modules
UARTs PTM - NXP Semiconductors
PCIe UARTs - MaxLinear
UARTs with Integrated Level Shifters - MaxLinear
XR21V141x Full-Speed USB UART Family - MaxLinear
Blogs
PSoC 6 PDM-PCM
Raspberry Pi RP2040 Microcontroller Now Available
TechForum
PSoC UART Example
Configuring and Using the UART Interface on the DK-S124
UART (VHDL)
More TechForum Posts on UARTs
