This Product Selection Guide contains information to help select products in the Chemicals, Cleaners category on DigiKey.com
Chemicals with specialized formulations and delivery systems for cleaning, degreasing, lubrication, dissolving, dusting, freezing, or inhibiting corrosion. Applications include adhesive removal, electrical contact cleaning, glass and plastic cleaning, hand cleaning or sanitizing, optics, aviation, electronics, and solder stencil cleaning.
SelectionCharacteristics
Type: The type, style, or nature of the product.
Chemical Component: Indicates a dominant ingredient or chemical basis for the formulation of the product.
Applications: Application is the type of equipment or environment the device will be used in, they are typically tested to ensure certain minimum standards for the application they are intended for.
Size: Indicates the volume, dimension, or weight the material nominally is.
Shipping Info: Indicates shipping restrictions where applicable.
ProductExamples
| MFR PART # | 824-1L |
| DIGIKEY PART # | 473-1355-ND |
| MANUFACTURER | MG Chemicals |
| DESCRIPTION | Cleaner, Solvent Electronics 1 Liter/35 fl oz |
| MFR PART # | 1671-10S |
| DIGIKEY PART # | 1873-1002-ND |
| MANUFACTURER | Techspray |
| DESCRIPTION | Duster Electronics 10 oz |
| MFR PART # | 7600 |
| DIGIKEY PART # | ST1100-ND |
| MANUFACTURER | ACL Staticide Inc |
| DESCRIPTION | Wipes, Pre-Saturated Stencils 5" x 8" |
| MFR PART # | 9222 |
| DIGIKEY PART # | 19-9222-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Cleaner Hand Cleaning, Sanitizing 16.9 fl oz |
MediaLinks
Videos
Techspray Contact Cleaner
MG Chemicals’ Glass Cleaner
MG Chemicals’ Super Contact Cleaner
ACL Staticide 8624 A4 All Purpose Flux Remover & Cleaner
MG Chemicals 404B - Electronics Contact Cleaner with Silicone
How to Reduce Static on Fiber Optic Connectors
MG Chemicals 401B - Nu-Trol Control Cleaner
TechForum
Cleaning your ESD mat
Fiber Optic Cable Cleaning
Cleaning PCB’s and electronic components
