This Product Selection Guide contains information to help select products in the Greases and Lubricants category on DigiKey.com
Greases and lubricants are used to protect surfaces against wear caused by friction. Grease is a semi-solid substance that becomes liquid when heated, while a substance considered a lubricant is already liquid. These are critical in protecting equipment in applications such as Industrial Automation & Controls to prevent downtime.
SelectionCharacteristics
Type: Indicates the specific type of product, typically by use and/or material composition.
Grade: Indicates the consistency or viscosity of the product as a numerical value defined by a third party. Greases typically use the NLGI (National Lubricating Grease Institute) numbering format and oils typically use the ISO (International Organization for Standardization) numbering format.
ISO Grades
Snippet courtesy of VISCOSITY CLASSIFICATIONS (premiumgrades.com) please see their website for more information.
Viscosity @ 40°C: The expected viscosity of the product at 40°C
Viscosity Index: A unitless indication of the change in the product’s viscosity due to temperature. A larger number = a higher resistance to change in viscosity.
Color: The dominant color of the product.
Texture: An indication of the feel of the material.
Thickener: Typically indicates the thickening agent used in the product.
Operating Temperature: Recommended operating temperature, typically given in a range or as a maximum. Exceeding these temperatures may affect performance or damage the material and other system components.
Base Oil: Indicates the material composition of the base oil of the product, where indicated.
Dropping Point: The temperature at which a drop of material falls from a test cup’s orifice due to a controlled application of temperature.
ProductExamples
| MFR PART # | SM22-N6 |
| DIGIKEY PART # | 2220-SM22-N6-ND |
| MANUFACTURER | CAIG Laboratories, Inc. |
| DESCRIPTION | SM22NP, SQUEEZE TUBE |
| MFR PART # | SM22-DN1 |
| DIGIKEY PART # | 2220-SM22-DN1-ND |
| DESCRIPTION | SM22DNP WITH DEOXIT D-SERIES (DX |
| MFR PART # | L27-MM-16 |
| DIGIKEY PART # | 2220-L27-MM-16-ND |
| DESCRIPTION | DEOXIT ELECTRICAL MARINE GREASE |
