This Product Selection Guide contains information to help select products in the RF Transceiver ICs category on DigiKey.com
RF Transceiver ICs are semiconductor devices that consist of a transmitter and a receiver in a single package. Transceivers are designed to function proficiently within an RF family or standard such as AISG, Bluetooth, ISM, VHF, Wi-Fi, cellular, RADAR, 802.15.4, and Z-Wave. They are further classified by the type of modulation and the specific protocol versions. Some ICs include a built-in microcontroller.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or configuration variables prior to shipping. For unverified products, please inquire with ProgCent.Techs@digikey.com.
Type: The primary mode of operation of the transceiver.
RF Family/Standard: Indicates the general application space or communications standard for which a device is intended for use.
Protocol: Enumerates the communications protocols and/or standard interfaces that a device supports or implements.
Modulation: Enumerates RF modulation schemes that a device employs or can be configured to employ.
Frequency: The specific radio frequency at which the device operates.
Data Rate (Max): Characterizes the maximum rate at which information can be transmitted or received by a device. Does not necessarily refer to the throughput rate for user data, see device datasheets for further information.
Power - Output: A device’s maximum rated output power in dB relative to 1 milliwatt or watt.
Sensitivity: The minimum RF signal strength required for the receiver to successfully demodulate and recover the data from the incoming signal.
Memory Size: The amount and type of memory available in the device.
Serial Interfaces: Indicates standard serial communication interfaces/protocols that are present or provisioned for on a device.
GPIO: Indicates the number of GPIO (General Purpose Input/Output) pins available on the device.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Receiving: Characterizes device current consumption while operating in an active state, awaiting a transmitted signal.
Current - Transmitting: Characterizes a device’s supply current consumption while actively transmitting.
Grade: Indicates whether the device is rated for automotive use.
Qualification: Indicates which automotive standard the device meets, if applicable.
| MFR PART # | ESP32-S3R8 |
| DIGIKEY PART # | 1904-ESP32-S3R8-ND |
| MANUFACTURER | Espressif Systems |
| DESCRIPTION | IC RF TxRx + MCU Bluetooth, WiFi 802.11b/g/n, Bluetooth v5.0 2.412GHz ~ 2.484GHz 56-VFQFN Exposed Pad |
| MFR PART # | EFR32BG12P232F1024GL125-B |
| DIGIKEY PART # | 336-5786-ND |
| MANUFACTURER | Silicon Labs |
| DESCRIPTION | IC RF TxRx + MCU Bluetooth Bluetooth v5.0 2.4GHz 125-VFBGA |
| MFR PART # | NRF24AP2-8CHQ32-T |
| DIGIKEY PART # | 4823-NRF24AP2-8CHQ32-T-ND |
| MANUFACTURER | Nordic Semiconductor ASA |
| DESCRIPTION | IC RF TxRx Only General ISM > 1GHz ANT™ 2.4GHz 32-VFQFN Exposed Pad |
MediaLinks
Videos
Atmel Wireless RF Transceiver - AT86RF212
Articles
How to Implement a Mesh Network for the Smart Home
How to Design Wireless Personal Area Networks
Wireless Protocols Control Energy Efficiency
Software-Defined Radio Advanced RF Transceiver
Product Training Modules
SPIRIT1 RF Transceiver Overview - STMicro
LMS6002DFN Multi-Function RF - Lime Micro
AT86RF232 Lo Pwr 2.4GHz Wireless Trans - Microchip
ATmega128RFA1 Wireless MCU - Microchip
Blogs
Blogs on RF Tranceivers
TechForum
TechForum posts on RF Transceivers
