Tape Dispensers
This Product Selection Guide contains information to help select products in the Tape Dispensers category on DigiKey.com
Tape Dispensers are devices that are used to hold and cut adhesive tape for home, office or industrial uses. Tape dispensers can be handheld or desk mount for a range of tape sizes ranging from 0.75 inches to 8 inches in width. Special features such as antistatic construction, hand breaks, multiple rolls per dispenser, or knifes are available.
SelectionCharacteristics
Type: Indicates the style and configuration of the dispenser.
Tape Width - Max: The maximum width of tape the dispenser was designed for use with.
ProductExamples
MFR PART # HB902
DIGIKEY PART # 3M161605-ND
MANUFACTURER 3M
DESCRIPTION TAPE DISPENSER HAND 2" WIDE
DATASHEET Click Here
MFR PART # HB903
DIGIKEY PART # 3M157461-ND
MANUFACTURER 3M
MFR PART # HB900
DIGIKEY PART # 3M15551-ND
MANUFACTURER 3M
DESCRIPTION TAPE DISPENSER 1" WIDE 3" CORE
If you have any general questions on the specifications for selecting Tape Dispensers, please reply using the button below. If you have questions on specific Tape Dispensers please post those questions in the Tape, Adhesives & Materials category.
Would we be allowed to post updated dispensers in this thread?
You should be able to. What would you like to add?
​We noticed previous post regarding 3M tapes and other’s mentioning foil tapes, our line of dispensers i.e the TDA080 and ZCM1000 units are able to cut most of those tapes and we wanted to highlight those dispensers for everyone
It’s really a post about the specs and the capability of each unit with a brief description of the manufacturing tapes it works with
It would be preferred if such content were posted as a standalone thread in the Tape, Adhesives & Materials category mentioned above. Selection guide threads are intended for generalized information regarding nomenclature, taxonomy, and related selection considerations, rather than information that is specific to any given vendor/product.
Thank you for confirming
Thanks for sharing this detailed Product Selection Guide. The breakdown of tape width compatibility and configuration types is especially helpful when selecting the right dispenser for specific industrial or workspace needs.
From a broader digital perspective, I find it interesting how structured selection guides like this improve decision-making efficiency. Clear specifications, comparison points, and defined use-cases reduce confusion — whether it’s choosing physical tools like tape dispensers or comparing different technical builds of software applications.
In online communities where users analyze different Android app versions (for example, anime-inspired projects related to Doraemon), having structured comparison insights also helps users determine compatibility, performance stability, and feature differences.
For readers interested in structured version breakdowns and performance comparisons in Android applications, you can explore more under the anchor text:
Doraemon x version comparison guide
