This Product Selection Guide contains information to help select products in the Ferrite Disks and Plates category on DigiKey.com
Ferrite disks and plates provide a simple and cost-effective solution for radiated and inductively coupled electromagnetic interference. They can be utilized either as inductively coupled components or EMI shields, and can be installed directly on the EMI source.
SelectionCharacteristics
Filter Type: Indicates the shape of the device.
Size/Dimension: The physical dimensions of the device. Typically length X width or diameter.
Height - Seated (Max): Indicates how far the device will extend above the surface to which it has been attached.
ProductExamples
| MFR PART # | HM0787-100 |
| DIGIKEY PART # | 240-2248-ND |
| MANUFACTURER | Laird-Signal Integrity Products |
| DESCRIPTION | FERRITE EMI DISC 20MM X 1.27MM |
| MFR PART # | 2644245701 |
| DIGIKEY PART # | 1934-1025-ND |
| MANUFACTURER | Fair-Rite Products Corp. |
| DESCRIPTION | FERRITE PLATE 7.4MMX4.9MMX1.5MM |
MediaLinks
TechForum
Protection with EMC Ferrites
Choosing the Right EMC Ferrite
