This Product Selection Guide contains information to help select products in the Cable Ferrites category on DigiKey.com
Ferrite cores are devices that are designed to prevent high frequency noise or EMI (electromagnetic interference). These ferrite cores are made to be placed on cables or wires. Some key characteristics are the type (flat or round), the design (clamp, clip, hinged, solid, or tubular), the inner and outer dimensions, the length, the mounting type (cable tie, chassis mount, or free-hanging), and the impedance at a specific frequency.
SelectionCharacteristics
Type: Defines if the ferrite is flat or round.
Design: Indicates the style and configuration of the device.
Impedance @ Frequency: Characterizes the total magnitude of opposition to AC current flow through a device, and the test frequency at which the characterization is made.
Material: Indicates the material composition of the device.
Inner Dimension: Indicates nominal dimensions of the aperture in a core through which a conductor is intended to be passed.
Outer Dimension: Indicates exterior dimensions of a core, along a cross section through which a conductor or cable is intended to pass.
Ratings: Minimum performance standards of the device, which are typically set by a third party.
Length: Indicates the overall length of the part.
ProductExamples
| MFR PART # | 5961004901 |
| DIGIKEY PART # | 1934-1294-ND |
| MANUFACTURER | Fair-Rite Products Corp. |
| DESCRIPTION | FERRITE CORE |
| MFR PART # | 2661000301 |
| DIGIKEY PART # | 1934-1459-ND |
| DESCRIPTION | FERRITE CORE 54OHM SOLID 1.30MM |
| MFR PART # | 431173951 |
| DIGIKEY PART # | 1934-1429-ND |
| DESCRIPTION | FERRITE 180OHM HINGED 5.11MM |
MediaLinks
TechForum
Protection with EMC Ferrites
Choosing the Right EMC Ferrite
