This Product Selection Guide contains information to help select products in the Solder Sleeve category on DigiKey.com
Solder Sleeves are small, hollow pieces of heat shrinkable tubing that have rings of solder incorporated into them. As they are heated, the tubing shrinks making a mechanical bond between the wires inserted into them. At the same time, the solder melts forming an electrical connection, securely splicing wires together. Coming in a variety of diameters and lengths with special features such as environmental resistances and pre-installed lead wires, solder sleeves are suitable for a wide range of wire sizes and applications.
SelectionCharacteristics
Type: Indicates the style and configuration of the part.
Diameter: The nominal unrecovered diameter of the sleeve, with both dimensions given for multi-diameter step-up parts.
Length: Indicates the overall length of the part.
Color: The dominant color of the part.
Features: These are different capabilities or properties of the device such as 2-part, environment resistant, or pre-installed braid.
ProductExamples
| MFR PART # | CWT-9002 |
| DIGIKEY PART # | CWT-9002-ND |
| MANUFACTURER | TE Connectivity Raychem Cable Protection |
| DESCRIPTION | Wire to Wire Solder Sleeve Clear 0.105" (2.67mm) |
| MFR PART # | CWT-9-W122-5 |
| DIGIKEY PART # | CWT-9-W122-5-ND |
| MANUFACTURER | TE Connectivity Aerospace, Defense and Marine |
| DESCRIPTION | Wire to Wire Solder Sleeve Clear 0.343" (8.71mm), 0.362" (9.19mm) |
| MFR PART # | FSLV14 CL078 |
| DIGIKEY PART # | FSLV14CL078-ND |
| MANUFACTURER | Alpha Wire |
| DESCRIPTION | Wire to Wire Solder Sleeve Clear 0.180" (4.57mm), 0.200" (5.08mm) |
| MFR PART # | SO96-1-55-22-90 |
| DIGIKEY PART # | SO96-1-55-22-90-ND |
| DESCRIPTION | Wire to Wire Solder Sleeve Transparent - Blue 0.075" (1.91mm), 0.105" (2.67mm) |
MediaLinks
TechForum
Solder Sleeve Solderability?
