This Product Selection Guide contains information to help select products in the Spiral Wrap, Expandable Sleeving category on DigiKey.com
Spiral wrap, or expandable sleeving, are designed to aid in wire management. They are made from various flexible materials to allow the cover, slit wrap, self wrap, sleeve, or spiral wrap to be easily manipulated around wire bundles. They are defined by the type, inner and outer diameters (expanded and non-expanded), material, color, and length. Some offer abrasion, liquid, and/or environmental protection options.
SelectionCharacteristics
Type: Defines the primary construction style of the device, indicating which type of product it is and determining its general usage.
Type Attributes: Provides differentiation among products of a similar type, having differences in construction or intended application.
Diameter - Inside, Non-Expanded: Nominal inside diameter of the material in its constricted state.
Diameter - Inside, Expanded: Nominal inside diameter of the material in its dilated state.
Diameter - Outside, Non-Expanded: Nominal outside diameter of the material in its constricted state.
Material: Indicates the material composition of the product.
Color: The dominant color of the product.
Length: Indicates the overall of the product.
Wall Thickness: The thickness dimension of the product’s walls.
Heat Protection: Indicates product resistance to heat or flame as indicated by the manufacturer.
Abrasion Protection: Indicates product resistance to various forms of mechanical abuse, as indicated by the manufacturer.
Liquid Protection: Indicates product resistance to fluids or fluid hazards as indicated by the manufacturer.
Environment Protection: Indicates product resistance to atmospheric hazards as indicated by the manufacturer.
Features: These are different capabilities or properties of the device such as clean cut or fungus resistant.
Material Flammability Rating: Ensures compliance with the relevant UL Flammability Rating.
UL94 Small Scale Flammability - Relative Comparison
Image from UL FLAMMABILITY – WHAT IT MEANS IN THE UL PRODUCT RECOGNITION PROCESS (faa.gov) Please see their website for more information.
Width: Indicates the overall width of the product.
ProductExamples
| MFR PART # | PTN0.13BK225 |
| DIGIKEY PART # | 1030-PTN0.13BK225-ND |
| MANUFACTURER | Techflex |
| DESCRIPTION | Sleeve X 225’ (68.58m) Black |
| MFR PART # | SW3 NA005 |
| DIGIKEY PART # | ASW3-100-ND |
| MANUFACTURER | Alpha Wire |
| DESCRIPTION | Spiral Wrap 0.375" (9.52mm) X 100’ (30.48m) Natural |
| MFR PART # | CLT100F-C3 |
| DIGIKEY PART # | 298-13533-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Slit Wrap 1.103" (28.02mm) X 100’ (30.48m) Orange |
| MFR PART # | 170-03143 |
| DIGIKEY PART # | 170-03143-ND |
| MANUFACTURER | HellermannTyton |
| DESCRIPTION | Self Wrap 0.800" (20.32mm) X 100’ (30.48m) Black |
