This Product Selection Guide contains information to help select products in the Spiral Wrap, Expandable Sleeving category on DigiKey.com
Hollow tubes of plastic or other materials with both ends open. The tube is split down the length of the tube and the seam is tucked into or over the tube, or the tube has a spiral cut down the length of the tube allowing the item to expand. A special tool is available to aid in installation.
SelectionCharacteristics
Tool Type: Indicates the style and configuration of the tool.
ProductExamples
| MFR PART # | HKB0.00WH |
| DIGIKEY PART # | 1030-HKB0.00WH-ND |
| MANUFACTURER | Techflex |
| DESCRIPTION | Hot Knife, Bench Mount For Sleeving |
| MFR PART # | CAT-15-PP |
| DIGIKEY PART # | RPC3557-ND |
| MANUFACTURER | Essentra Components |
| DESCRIPTION | Installation Tool For SHR-15 Slit Harness Wrap |
| MFR PART # | PWT50 |
| DIGIKEY PART # | 298-14166-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Installation Tool For Pan-Wrap™ PW 1/2" Slit Harness Wrap |
MediaLinks
Videos
Fit Wrappable Sleeving Tool | DigiKey
TechForum
How to cut expandable sleeving
