This Product Selection Guide contains information to help select products in the Cold Shrink Tape, Tubing category on DigiKey.com
Cold Shrink Tubing are hollow pieces of plastic tubing with both ends open. The tubing remains expanded until the center core of the tubing is removed. The tubing then shrinks to seal the items inserted into the tubing. Cold Shrink Tape provides a covering without any adhesive or mastic. The tape material reacts with itself to form a protective layer.
SelectionCharacteristics
Type: Describes the physical form, distinguishing features, or intended purpose of the device.
Length: The length of the device, given in Feet (Millimeters, Inches).
Diameter: For tubing, indicates the diameter of the shrink tube. Both the contracted and expanded diemeters are given as Contracted Diameter ~ Expanded Diameter, in Inches (Millimeters).
Width: For tape, indicates the width of the cold shrink tape.
Material: Indicates the material composition of the device.
Thickness: Indicates the wall thickness or material thickness of a tube or tape product. Given in Inches (Millimeters).
Color: The dominant color of the device.
ProductExamples
| MFR PART # | 8424-8 |
| DIGIKEY PART # | 8424-8-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Black Cold Shrink Tubing 0.10" ~ 0.82" (2.5mm ~ 20.8mm) X 0.667’ (203.20mm, 8.00") |
| MFR PART # | ST250-1 BLK |
| DIGIKEY PART # | W211-ND |
| MANUFACTURER | Daburn Electronics |
| DESCRIPTION | Black Cold Shrink Tape 1.000" (25.4mm) X 16.00’ (4.88m) |
| MFR PART # | SDL-TNS-65-1 |
| DIGIKEY PART # | 2807-SDL-TNS-65-1-ND |
| MANUFACTURER | Gamma Electronics |
| DESCRIPTION | Black Cold Shrink Tubing 0.25" ~ 0.95" (6.4mm ~ 24.1mm) X 0.213’ (65.00mm, 2.56") |
| MFR PART # | EC-2 |
| DIGIKEY PART # | 3M156887-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Black Cold Shrink End Cap 0.63" ~ 1.18" (15.9mm ~ 30.1mm) X |
MediaLinks
Videos
EPDM vs Silicone Cold Shrink: Shrink Ratio
3M - Cold Shrink Splice Training
Magic Tape (Self Amalgamating Tape)
RF Weather Proofing Installation
