This Product Selection Guide contains information to help select products in the Heat Shrink Tubing Kits category on DigiKey.com
Products in this family are assortments of heat shrinkable insulating tubing, from a single manufacturer and product series but varying in size and/or color, offered in kit form to provide a convenient means of acquiring a range of product likely to be found useful in the course of maintenance, repair, or product development operations. Different product series exhibit different characteristics, such as maximum ratio of pre- and post-shrink diameters, mechanical rigidity of the product after shrinking, and presence of an inner adhesive layer.
SelectionCharacteristics
Values: Indicates the number and/or type of items the kit contains.
Diameter: Indicates the diameter(s) included as well as the quantity of each.
Color: Indicates the colors of items that are included in the kit.
Shrinkage Ratio: The nominal ratio of a material’s inner diameter before and after recovery or “heat shrinking”.
Shelf Life: Indicates the period of time for which material properties and performance are expected to remain within the manufacturer’s specifications, when stored and handled as indicated.
ProductExamples
| MFR PART # | Q2-F3X-QK1-01-6IN-106 |
| DIGIKEY PART # | Q842-KIT-ND |
| MANUFACTURER | Qualtek |
| DESCRIPTION | Heat Shrink Kit 3 to 1 Black |
| MFR PART # | Q2-Z-RK1-3/32-01-6IN-32 |
| DIGIKEY PART # | Q933-ND |
| DESCRIPTION | Heat Shrink Kit 2 to 1 Black |
| MFR PART # | HS-ASST-10 |
| DIGIKEY PART # | 2368-HS-ASST-10-ND |
| MANUFACTURER | NTE Electronics, Inc |
| DESCRIPTION | Heat Shrink Kit 2 to 1 Black, Blue, Clear, Green, Red, White, Yellow |
| MFR PART # | HS050 |
| DIGIKEY PART # | 438-HS050-ND |
| MANUFACTURER | Twin Industries |
| DESCRIPTION | Heat Shrink Kit 2 to 1 Blue, Red, Yellow, White |
