This Product Selection Guide contains information to help select products in the Drums, Pails category on DigiKey.com
SelectionCharacteristics
Material: Indicates the material composition of the device.
Capacity: Indicates the maximum capacity the part is rated for.
Size / Dimension: The physical dimensions of the device. Typically diameter by width by height.
Ratings: Minimum performance standards of the device, which are typically set by a third party.
ProductExamples
| MFR PART # | 987432 |
| DIGIKEY PART # | 3539-987432-ND |
| MANUFACTURER | Vestil |
| DESCRIPTION | 5 GAL. OPEN HEAD STEEL PAIL, RUS |
| MFR PART # | CQ5506 |
| DIGIKEY PART # | 3539-CQ5506-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | CARBON STEEL OPEN-HEAD DRUMS, BO |
| MFR PART # | 921199 |
| DIGIKEY PART # | 3539-921199-ND |
| MANUFACTURER | Eagle Mfg |
| DESCRIPTION | 2 DRUM BUDGET BASIN, 51-1/2X26-1 |
