This Product Selection Guide contains information to help select products in the Drum Cradles, Lifts, Trucks category on DigiKey.com
SelectionCharacteristics
Type: The type, style, or nature of the device.
Capacity: Indicates the maximum weight limit of the part.
Material: Indicates the material composition of the device.
Wheel Type: Indicates the material composition of the wheels of the device.
Wheel Size: Indicates the diameter of the wheels of the device.
Color: The dominant color(s) of the device.
Size / Dimension: The physical dimensions of the device. Typically length by width.
ProductExamples
| MFR PART # | CTO15N-LED-110V |
| DIGIKEY PART # | 3539-CTO15N-LED-110V-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | HIGH-PROFILE LED PERMANENT MOUNT |
| MFR PART # | HJ365 |
| DIGIKEY PART # | 3539-HJ365-ND |
| DESCRIPTION | PORTABLE HYDRAULIC DRUM JACK, ST |
| MFR PART # | DLGH500 |
| DIGIKEY PART # | 3539-DLGH500-ND |
| DESCRIPTION | OPEN & CLOSED HEAD DRUM LIFTER 1 |
