This Product Selection Guide contains information to help select products in the Fiber Optic Cables category on DigiKey.com
Fiber Optics are cables that contains a glass or plastic thread enclosed within a jacketed material.
SelectionCharacteristics
Style: Indicates whether it is a standard or multi-fiber cable.
Type: Indicates the type of optical channel used in the cable.
Length: Indicates the length of the cable.
Core Diameter: Typical diameter of light-carrying core material.
Cladding Diameter: Typical outer diameter of the material separating the optical fiber core from the jacket.
Jacket (Insulation) Material: Indicates the material composition of the outermost jacketing of the cable.
Jacket (Insulation) Diameter: Indicates the diameter of a cable/wire product’s outermost layer; a product’s overall thickness.
Tensile Strength: The maximum pulling force or stress that can be applied to a product or material before failure occurs, under manufacturer-defined test conditions.
Attenuation - Typ: Manufacturer’s characterization of optical signal loss per unit length of cable.
Refractive Index - Core: Defines the speed of light through the core material, in relation to the speed of light in a vacuum. A refractive index of 1.5, for example, indicates that light travels 1.5 times slower through the cable than it does through a vacuum.
Jacket Color: Indicates the color of the outermost insulation layer of a wire or cable product.
Ratings: Minimum performance standards of the cable, which are typically set by a third party.
Features: These are different capabilities or properties of the device such as
fiber count and zipcord.
ProductExamples
| MFR PART # | HFBR-EUS100Z |
| DIGIKEY PART # | 516-2086-ND |
| MANUFACTURER | Broadcom Limited |
| DESCRIPTION | Fiber Optic Cable POF 328.1’ (100.0m) |
| MFR PART # | TC-1000W |
| DIGIKEY PART # | 107-TC-1000W-ND |
| MANUFACTURER | Industrial Fiber Optics |
| DESCRIPTION | Fiber Optic Cable Black 1640.4’ (500.0m) |
| MFR PART # | N549-01K |
| DIGIKEY PART # | TL2136-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | Fiber Optic Cable Orange Multimode, Duplex 125µm 1000.0’ (304.8m) |
| MFR PART # | FOKPX06 |
| DIGIKEY PART # | FOKPX06-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Fiber Optic Cable Black Multimode 125µm |
MediaLinks
Videos
How do Fiber Optic Cables Work
Articles
When is Optical Transmission Your Best Choice
Use Industrial Ethernet for Control Networks
Blogs
The Basics of Fiber Optic Cables
TechForum
Fiber Optic Cable Splicing
Fiber Optic Cable Cleaning
