Drum Pumps
This Product Selection Guide contains information to help select products in the Drum Pumps category on DigiKey.com
SelectionCharacteristics
Pump Type: Indicates what kind of mechanism is used for the pump.
Pump Rate: Defines the rate of flow for the pump.
Material: Defines what materials are used for the pump.
Specifications: Any technical specifications pertaining to the part.
Features: More technical specifications pertaining to the part.
ProductExamples
MFR PART # 5512B
DIGI-KEY PART # 3539-5512B-ND
MANUFACTURER Action Pump
DESCRIPTION OIL BUCKET PUMPS, FOR 5-GAL. BUC
MFR PART # 3005
DIGI-KEY PART # 3539-3005-ND
DESCRIPTION CAST IRON ROTARY DRUM PUMP, 10 G
MFR PART # 277495
DIGI-KEY PART # 3539-277495-ND
MANUFACTURER Royal Sovereign
DESCRIPTION 1 ROW MANUAL COIN SORTER
If you have any general questions on the specifications for selecting Drum Pumps, please reply using the button below. If you have questions on specific Drum Pumps please post those questions in the Equipment, Tools & Supplies category.
