This Product Selection Guide contains information to help select products in the Water Fountains and Refilling Stations category on DigiKey.com
SelectionCharacteristics
Number of Stations: Number of liquid dispensers the item has.
Installation Type: Indicates how/where the product is mounted.
Voltage: The voltage the equipment is designed to be powered by.
Current Rating (Amps): This rating indicates the nominal amount of current you would expect the device to draw during normal operation.
Refrigerated: Indicates if the device cools the liquid.
Color: The dominant color of the device.
Height (Inches): Indicates the overall height of the product.
Width (Inches): Indicates the overall width of the product.
Length (Inches): Indicates the overall length of the product.
Depth (Inches): Indicates the overall depth of the product.
ProductExamples
| MFR PART # | LZWSSM |
| DIGIKEY PART # | 3539-LZWSSM-ND |
| MANUFACTURER | Elkay |
| DESCRIPTION | Stainless Steel Surface Water Bottle Filling Station, Wall Mount |
| MFR PART # | TY-LWYR91UT |
| DIGIKEY PART # | 3539-TY-LWYR91UT-ND |
| MANUFACTURER | Global Industrial |
| DESCRIPTION | Black Floor Water Dispenser, Tri-Temp |
| MFR PART # | EDF15R |
| DIGIKEY PART # | 3539-EDF15R-ND |
| DESCRIPTION | Stainless Steel Wall Water Fountain, Bracket Style/Wall Mount |
