This Product Selection Guide contains information to help select products in the Bottles, Syringes category on DigiKey.com
Bottles and syringes are dispensing tools made for precision application uses. They are available in various types of plastic or glass with multiple tip options in a large capacity range.
SelectionCharacteristics
Type: The type, style, or nature of the product.
Tip Type: Indicates the style of tip or lack thereof.
Capacity: The amount of material the item is designed to handle/dispense.
Inner Diameter: Typically indicates inner dimension for the dispensing end of the item.
Outer Diameter: Typically indicates outer dimension for the dispensing end of the item.
Length: Indicates the nominal length of the item.
Height: Indicates the nominal height of the item.
Color: The dominant color of the device.
Material: Indicates the material composition of the device.
Features: These are different capabilities or properties of the device such as ESD safe, refillable, or UV resistant.
ProductExamples
MFR PART # | CQ10CC-QTY1 |
DIGI-KEY PART # | 315-CQ10CC-QTY1-ND |
MANUFACTURER | Chip Quik Inc. |
DESCRIPTION | 10CC SYRINGE (WITH PISTON, FRONT |
DATASHEET | Click Here |
MFR PART # | FD-2 |
DIGI-KEY PART # | FD-2-ND |
MANUFACTURER | Chemtronics |
DESCRIPTION | NEEDLE FLUX DISPENSER - .020 TUB |
MFR PART # | 35573 |
DIGI-KEY PART # | 16-1360-ND |
MANUFACTURER | MENDA/EasyBraid |
DESCRIPTION | FLUX DISP ESD SAFE W/TIP YELLOW |
MediaLinks
Videos
Properly Load a Syringe
Will It Break? Standard Glass Bottle vs. Safety-Coated Glass Bottle | MENDA
