This Product Selection Guide contains information to help select products in the Tweezers category on DigiKey.com
Tweezers are tools used for manipulating objects too small to be handled with human fingers. They are available in a wide array of lengths and materials such as plastic for nonconductivity, carbon steel and titanium for strength, and stainless steel for the ability to sterilize. They are differentiated by tip style, type and shape such as angled, curved, hook and straight.
SelectionCharacteristics
Features: These are different capabilities or properties of the device such as ESD safe, heat resistant, or serrated.
Tip Style: Indicates the shape of the tweezer tip.
Tip Type: Indicates secondary characteristics of the shape of the tweezer tip.
Tip Shape: Indicates shape of the tip end of the tweezers.
Length - Overall: Indicates the overall length of the tweezers.
Pattern Number: A designator referencing tweezer characteristics such as tip size, shape, serrations, etc.
Material: Indicates the material composition of the tweezers.
ProductExamples
| MFR PART # | 15A-RW |
| DIGIKEY PART # | 2827-15A-RW-ND |
| MANUFACTURER | Excelta Corporation |
| DESCRIPTION | Tweezers Cutter End Cutter 15ARW 4.50" (114.3mm) |
| MFR PART # | 709.CF.ITU |
| DIGIKEY PART # | 2014-709.CF.ITU-ND |
| MANUFACTURER | Ideal-tek S.A. |
| DESCRIPTION | Tweezers ESD Safe Flat Square 4.53" (115.0mm) |
| MFR PART # | TOL-12572 |
| DIGIKEY PART # | 1568-1624-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | Tweezers ESD Safe, Self Closing Pointed Fine |
MediaLinks
Videos
How many Tweezer materials can you imagine?
What is the International Tweezer Style?
Tweezer Coatings
Measure Up with Smart Tweezers
More Videos on Tweezers
Product Training Modules
Tweezers Selection Guide
Smart Tweezer™ - Ideal-tek
TechForum
Tweezer Tips - Fine Measurement
