This Product Selection Guide contains information to help select products in the Tips, Nozzles category on DigiKey.com
Dispensing Equipment Tips and Nozzles are the ends used on containers to precisely apply a wide range of materials. The types are mixing nozzles and needle tip dispensers, available from 14 to 30 gauge and in a variety of colors.
SelectionCharacteristics
Type: The type, style, or nature of the product.
Tip Type: Indicates the style of the dispensing tip.
Gauge: A measure of dispenser needle diameter. Lower gauge numbers indicate a larger needle.
Outer Diameter: Typically indicates outer dimension for the dispensing end of the item.
Inner Diameter: Typically indicates inner dimension for the dispensing end of the item.
Color: The dominant color of the device.
Number of Pieces: The quantity of like items within a package that is sold as a single item.
ProductExamples
| MFR PART # | 8MT-50 |
| DIGIKEY PART # | 473-1379-ND |
| MANUFACTURER | MG Chemicals |
| DESCRIPTION | MIXING NOZZLE 50ML 5/PK |
| MFR PART # | 35567 |
| DIGIKEY PART # | 16-1363-ND |
| MANUFACTURER | MENDA/EasyBraid |
| DESCRIPTION | Clear |
| MFR PART # | EPX NOZ 9171 |
| DIGIKEY PART # | 3M157693-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | NOZZLE EPX GREEN SHORT 48.5/50ML |
| MFR PART # | BT-02-50M |
| DIGIKEY PART # | 345-1554-ND |
| MANUFACTURER | Wakefield-Vette |
| DESCRIPTION | BONDATHERM EQUALIZER STATIC MIXE |
MediaLinks
Videos
Panasonic Quick Clips ER-V Static Ionizer Nozzles
Blogs
How to Clean and Maintain Your 3D Printer Nozzle
