This Product Selection Guide contains information to help select products in the Thermistor Kits category on DigiKey.com
Thermistor Kits are a grouping of NTC, PTC, or NTC & PTC thermistors that change their resistance relative to changes in temperature. The kits come in through-hole, surface mount, eyelet, or probe styles, with an assortment of values and pieces ranging from 6 (6 values – 1 each) to 5725 pieces (109 values – mixed quantities) with temperature ranges from -55°C to 170°C.
SelectionCharacteristics
Kit Type: A general description of the function and contents of the kit.
Quantity: Indicates the number of pieces contained in the kit.
Temperature Range: Recommended operating temperature, typically given in a range or as a maximum. Exceeding these temperatures may affect performance or damage the device and other system components. Indicates the span of operating temperatures the kit includes.
ProductExamples
| MFR PART # | B59002Z0999A099 |
| DIGIKEY PART # | 495-6732-ND |
| MANUFACTURER | EPCOS - TDK Electronics |
| DESCRIPTION | PTC Thermistor Kit Assorted |
| MFR PART # | NTC0201-KIT |
| DIGIKEY PART # | 445-174937-KIT-ND |
| MANUFACTURER | TDK Corporation |
| DESCRIPTION | NTC Thermistor Kit 90 Pieces (9 Values - 10 Each) |
| MFR PART # | B57999A9999A100 |
| DIGIKEY PART # | 495-B57999A9999A100-ND |
| DESCRIPTION | NTC Thermistor Kit 10 Pieces - 10 Values (1 Each) |
