This Product Selection Guide contains information to help select products in the RF Multiplexers category on DigiKey.com
RF Multiplexers use bi-directional bandpass filters to combine RF signals for transmission through a single coaxial cable or to split a combined signal into separate signals for transmission through independent coax cables. Types of multiplexing include diplexing, and duplexing. triplexing, quadplexing, and quintplexing. Multiplexors are differentiated by their frequency bands, low band attenuation, high band attenuation, return loss, and mounting type.
SelectionCharacteristics
Type: The specific configuration and functionality of the multiplexer.
Frequency Bands (Low / High): Indicates the frequency ranges over which a device is intended to be used.
Low Band Attenuation (min / max dB): Minimum/typical amount by which signals at high-band frequencies are attenuated, as measured at the low-band port.
High Band Attenuation (min / max dB): Minimum/typical amount by which signals at low-band frequencies are attenuated, as measured at the high-band port.
Return Loss (Low Band / High Band): Characterizes losses due to transmission line reflections for the low- and high-frequency ports of the device.
Grade: Indicates whether the device is rated for automotive use.
Qualification: Indicates which automotive standard the device meets, if applicable.
Mounting Type : Indicates how the device is attached.
| MFR PART # | DPX105850DT-6018A1 |
| DIGIKEY PART # | 445-181438-2-ND |
| MANUFACTURER | TDK Corporation |
| DESCRIPTION | RF Diplexer 2.4GHz ~ 2.5GHz / 5.15GHz ~ 5.85GHz 0402 (1005 Metric), 4 PC Pad |
| MFR PART # | TPX205950MT-7052C1 |
| DIGIKEY PART # | 445-TPX205950MT-7052C1TR-ND |
| DESCRIPTION | RF Triplexer 1.559GHz ~ 1.606GHz / 4.9GHz ~ 5.95GHz 0805 (2012 Metric), 8 PC Pad |
| MFR PART # | B39212B8092P810 |
| DIGIKEY PART # | B39212B8092P810TR-ND - Tape & Reel (TR) |
| MANUFACTURER | Qualcomm (RF front-end (RFFE) filters) |
| DESCRIPTION | RF Duplexer 1.92GHz ~ 1.98GHz / 2.11GHz ~ 2.17GHz 9-SMD, No Lead |
