This Product Selection Guide contains information to help select products in the RF Power Dividers/Splitters category on DigiKey.com
RF Power Dividers/Splitters are designed to break an input signal into two or more output signals with a specific phase and amplitude. The insertion loss ranges from 0.1 dB to 6 dB with a frequency range of 0 Hz to 45 GHz.
SelectionCharacteristics
Insertion Loss: A measure of the difference in power applied to a device’s input port and the portion thereof that appears at its isolated port, when properly terminated.
Frequency: The frequency or frequencies this product is designed to be compatible with.
Specifications: This selection indicates the attributes which expound on a product’s abilities but are not a standard attribute universal to this product family.
Size / Dimension: The physical dimensions of the device. Typically listed length by width.
MFR PART # | PD2328J5050S2HF |
DIGIKEY PART # | 1173-1098-2-ND - Tape & Reel (TR) |
MANUFACTURER | TTM Technologies, Inc. |
DESCRIPTION | RF Power Divider 2.3 GHz ~ 2.8 GHz Isolation (Min) 17dB, 19dB Return Loss 0805 (2012 Metric) |
DATASHEET | Click Here |
MFR PART # | SBTC-2-10L+ |
DIGIKEY PART # | 3157-SBTC-2-10L+TR-ND - Tape & Reel (TR) |
MANUFACTURER | Mini-Circuits |
DESCRIPTION | RF Power Divider 5 MHz ~ 1 GHz Isolation (Min) 20dB, 5° Imbalance (Max) 6-SMD (5 Leads), Flat Lead |
MFR PART # | PDR06380 |
DIGIKEY PART # | 1761-1123-ND |
MANUFACTURER | Knowles Dielectric Labs |
DESCRIPTION | RF Power Divider 0 Hz ~ 40 GHz 20dB Return Loss Module |
MediaLinks
Articles
Routing RF Signals Using Power Dividers/Combiners
