This Product Selection Guide contains information to help select products in the RF Power Controller ICs category on DigiKey.com
RF power control ICs are devices used for measuring the amount of radio frequency power in a signal being transmitted, and providing a corresponding feedback signal to a programmable amplifier or similar device to allow a desired level of transmitted signal power to be maintained.
SelectionCharacteristics
RF Type: Indicates the general application space or communications standard for which a device is intended for use.
Frequency: The frequency or frequencies this product is designed to be compatible with.
Features: These are different capabilities or properties of the device such as dual band, quad band, or single output.
| MFR PART # | AD8311ACBZ-P7 |
| DIGIKEY PART # | 505-AD8311ACBZ-P7-ND |
| MANUFACTURER | Analog Devices Inc. |
| DESCRIPTION | RF Power Controller IC GSM 2.5GHz 6-WLCSP (1.45x0.95) |
| MFR PART # | LMV242LD/NOPB |
| DIGIKEY PART # | LMV242LD/NOPBTR-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | RF Power Controller IC Cellular, GSM, GPRS, TDMA, TD-SCDMA, WLL 450MHz ~ 2GHz 10-WSON (3x3) |
| MFR PART # | AD8315ARMZ-RL |
| DIGIKEY PART # | 505-AD8315ARMZ-RLTR-ND |
| DESCRIPTION | RF Power Controller IC DCS, GSM, ISM 100MHz ~ 2.5GHz 8-MSOP |
