This Product Selection Guide contains information to help select products in the OR Controllers, Ideal Diodes category on DigiKey.com
Ideal diode controllers, also called O-Ring controllers, are devices designed to control an external pass transistor (usually a FET) in a manner that allows current flow in only one direction, similar to a rectifier diode but with significantly lower conduction loss. Among other applications, they are commonly used for providing reverse-flow protection in power supplies designed to be connected in parallel for the sake of redundancy or increased output current capability.
SelectionCharacteristics
Type: Defines the primary construction style of the device, indicating which type of part it is and determining its general usage.
FET Type: Indicates the channel type of the power-handling FETs incorporated within a device, or of external FETs with which a device is designed for use.
Ratio - Input:Output: Indicates the number of signal inputs and outputs present in each functional circuit within a device.
Internal Switch(s): Indicates whether or not a device integrates the power transistor(s) needed for manipulation of the power source a device is intended to control.
Delay Time - ON: Typical latency from a control input to its corresponding output when the output is being asserted.
Delay Time - OFF: Typical latency from a control input to its corresponding output when the output is being de-asserted.
Current - Output (Max): The maximum amount of current that can be output by the device.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Applications: Application is the type of equipment or environment the device will be used in, typically they are tested and rated by a third party to ensure certain minimum standards for the application they are intended for.
ProductExamples
| MFR PART # | MAX40200AUK+T |
| DIGIKEY PART # | MAX40200AUK+TTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Analog Devices Inc./Maxim Integrated |
| DESCRIPTION | OR Controller Source Selector Switch P-Channel 1:1 SOT-23-5 |
| MFR PART # | LM73100RPWR |
| DIGIKEY PART # | 296-LM73100RPWRTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | OR Controller N+1 ORing Controller N-Channel 1:1 10-VQFN-HR (2x2) |
| MFR PART # | ICL7673CPAZ |
| DIGIKEY PART # | ICL7673CPAZ-ND |
| MANUFACTURER | Renesas Electronics America Inc |
| DESCRIPTION | OR Controller Source Selector Switch N and P-Channel 2:1 8-PDIP |
| MFR PART # | MP6973GS-Z |
| DIGIKEY PART # | 1589-MP6973GS-ZTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Monolithic Power Systems Inc. |
| DESCRIPTION | OR Controller Flyback N-Channel 1:1 8-SOIC |
MediaLinks
Videos
Videos on Ideal Diodes
Articles
ORing Controllers Facilitate Power Supply Design
Actively Seeking a Better ORing Solution
Articles on Ideal Diodes
Product Training Modules
LT4320 Ideal Diode Bridge Controller - ADI
