This Product Selection Guide contains information to help select products in the Crimpers, Applicators, Presses category on DigiKey.com
Crimpers, Applicators, and Presses are devices used to join wires to contacts by compressing the crimp portion of the contact. These devices may or may not contain a head or die set which is made specifically for the wire size and contact/terminal type being used. The tool types are applicator, bench press, crimp unit, hand crimper, hand press, hand tool, and pump unit. The tool actuation methods are AC powered, automated, battery powered, hydraulic, manual, or pneumatic.
SelectionCharacteristics
Tool Method: Indicates how the item’s crimping action is powered.
Tool Type: The type, style, or nature of the accessory.
Tool Type Feature: Special features or functions specific to crimping the device includes.
Wire Gauge or Range - AWG: The wire size or size range with which a product is designed for use, expressed in terms of American Wire Gauge.
Wire Gauge or Range - mm²: The wire size or size range with which a product is designed for use, expressed in terms of cross-sectional area in square millimeters.
Ratcheting: Indicates if the device includes a device that assists in the quality of the crimp operation by preventing early release of the item being crimped.
Wire Entry Location: Indicates the direction the wire can be inserted from relative to the rest of the crimping tool/body.
Features: These are different capabilities or properties of the device such as adjustable, crimp and strip, or pressure lock.
ProductExamples
| MFR PART # | 58074-1 |
| DIGIKEY PART # | A2031-ND |
| MANUFACTURER | TE Application Tooling |
| DESCRIPTION | Hand Crimper Tool Varies by Die Set |
| MFR PART # | 640160201 |
| DIGIKEY PART # | WM17552-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Hand Crimper Tool Rectangular Contacts |
| MFR PART # | 2990003-01 |
| DIGIKEY PART # | 380-1057-ND |
| MANUFACTURER | Stewart Connector |
| DESCRIPTION | Hand Crimper Tool Modular - RJ45 (8p8c) |
| MFR PART # | SQ28-10 |
| DIGIKEY PART # | 288-SQ28-10-ND |
| MANUFACTURER | American Electrical Inc. |
| DESCRIPTION | Hand Crimper Tool Ferrules |
MediaLinks
Videos
PRO-CRIMPER How-To Video
Modular Crimping with Klein Tools - Another Geek Moment
Elpress crimping of pre-insulated ring terminal
More videos on Crimpers
Product Training Modules
Secrets to a Successful Crimp
Blogs
The Importance of Good Crimp Tools
Making Consistent, Reliable Crimped Terminations
TechForum
Manual Crimp Tools vs. Automatic Crimp Tools: Pros and Cons
Generic Crimp Tool for Small Electronics
