This Product Selection Guide contains information to help select products in the Crimp Heads, Die Sets category on DigiKey.com
Crimp heads and die sets are components of modular tooling systems, most typically used for the assembly of crimp-on interconnect products to wire or cable materials. They are the component of such systems that mechanically interfaces with a workpiece, and by being modular or interchangeable, allow the use of a common mechanism for generating force or motion to be used for applying a range of interconnect products, as well as lowering replacement costs should damage or wear occur.
SelectionCharacteristics
Tool Type: Indicates the style and configuration of the device.
Specifications: This selection indicates the attributes which expound on a product’s abilities but are not a standard attribute universal to this product family.
Compatible Tools: Indicates other tooling components with which a device is designed for use.
Cable Group: Indicates the type(s) of cable material with which a connector is intended for use, in terms of standard designations or manufacturer model number.
ProductExamples
MFR PART # | S16RCM20 |
DIGI-KEY PART # | SOU1741-ND |
MANUFACTURER | Souriau-Sunbank by Eaton |
DESCRIPTION | Tool Crimp Head For Circular Contacts, 20-26 AWG |
DATASHEET | Click Here |
MFR PART # | 9990000621 |
DIGI-KEY PART # | 1195-2944-ND |
MANUFACTURER | HARTING |
DESCRIPTION | Tool Die Set For Backplane Contacts, 20-28 AWG |
MFR PART # | 58630-2 |
DIGI-KEY PART # | A120136-ND |
MANUFACTURER | TE Application Tooling |
DESCRIPTION | Tool Die Set For Quick Connects Terminals, 10-12 AWG |
MFR PART # | SK2-2 |
DIGI-KEY PART # | 889-2103-ND |
MANUFACTURER | Amphenol Sine Systems Corp |
DESCRIPTION | Tool Positioner For Contacts, 20-32 AWG |
