This Product Selection Guide contains information to help select products in the Vacuums category on DigiKey.com
Vacuums are designed to remove dust, dirt, soot, glass, pollens, color toner, lead, and fumes by sucking these particles into a holding bin or filter. Some vacuums can be converted into a blow vac for dust removal in tight spaces. The voltages range from 110VAC to 230VAC and includes hose, carrying case, nozzle, brush, filter, bags, and power cord.
SelectionCharacteristics
Tool Type: The type, style, or nature of the product.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Includes: Indicates items included with purchase.
Features: These are different capabilities or properties of the device such as ESD safe.
ProductExamples
| MFR PART # | 497ABG |
| DIGIKEY PART # | SCP688-ND |
| MANUFACTURER | SCS |
| DESCRIPTION | Electronics Vacuum 220VAC With 7 ft Hose, 8 ft Cord, Brush (2), Filter, Nozzles (3) ESD Safe |
| MFR PART # | 35852 |
| DIGIKEY PART # | EB1578-ND |
| MANUFACTURER | MENDA/EasyBraid |
| DESCRIPTION | Electronics Vacuum 110VAC With 6ft Hose, Brush, Detachable Power Cord, HEPA Filter, Nozzle (2) ESD Safe |
| MFR PART # | 4000-RH |
| DIGIKEY PART # | 2827-4000-RH-ND |
| MANUFACTURER | Excelta Corporation |
| DESCRIPTION | Hose With |
| MFR PART # | 4000-RF |
| DIGIKEY PART # | 2827-4000-RF-ND |
| DESCRIPTION | Filter With |
MediaLinks
Videos
Renesas RL78 Quick Solution: Handy Vacuum
SCS Electronic Service Vacuums
Articles
Robot Sensing for Challenges and Chores
TechForum
LG homebot vacuum cleaner cable connector
3M SCS 497 Vacuum Inlet Replacement
