This Product Selection Guide contains information to help select products in the Electroluminescent category on DigiKey.com
Electroluminescent (EL) wire, also known as Flexible Neon Wire, is a thin wire coated in phosphor in a tube that emits light along its entire length without heat radiation. EL wire consumes much lower power than that of LED lamps, and as such is the emerging standard in a new generation of lighting and display applications.
SelectionCharacteristics
Configuration: Indicates the overall shape of the part. Examples include panel, tape, and wire styles.
Color: The dominant color of the device.
Size/Dimension: The physical dimensions of the device. Typically length or length X width.
Contents: Indicates items included with purchase.
ProductExamples
MFR PART # | COM-12931 |
DIGIKEY PART # | 1568-1683-ND |
MANUFACTURER | SparkFun Electronics |
DESCRIPTION | EL WIRE - RED 3M (CHASING) |
DATASHEET | Click Here |
MFR PART # | 624 |
DIGIKEY PART # | 1528-1258-ND |
MANUFACTURER | Adafruit Industries LLC |
DESCRIPTION | PANEL ELECTROLUM EL 10X10CM BLUE |
MFR PART # | 631 |
DIGIKEY PART # | 631-ND |
DESCRIPTION | STARTER PK EL STRIP 100CM RED |
MediaLinks
Videos
Videos on Electroluminescent
Articles
Articles on Electroluminescent
TechForum
TechForum posts on Electroluminescent
