This Product Selection Guide contains information to help select products in the Lighting Fixtures category on DigiKey.com
Lighting Fixtures are ready-to-mount lighting solutions. These are available in a variety of styles and light types.
SelectionCharacteristics
Style: Describes the mounting type of the part.
Bulb Type/Size: Defines the size and shape of the bulb.
Finish: Indicates the color of the exterior of the part.
Wattage: For devices incorporating a lamp fixture, the maximum lamp power the fixture is rated to accommodate.
Voltage - Supply: Typically this represents the nominal voltage rating to which a device will meet its given specifications. Exceeding this voltage rating may damage the device and other system components.
Luminous Flux: Indicates the measurement of light energy emitted by a device.
CCT (K): Characterizes the perceived color of a nominally “white” light source, in terms of comparison to an ideal blackbody radiator. Devices with lower values appear more yellow, and those with higher values appear more blue.
ProductExamples
| MFR PART # | ESL-OPT-8-1129W-23050K |
| DIGIKEY PART # | 5112-ESL-OPT-8-1129W-23050K-ND |
| MANUFACTURER | ESL Vision |
| DESCRIPTION | 8 Round Watts and CCT Adj Down L |
| MFR PART # | 43319-RS |
| DIGIKEY PART # | 3127-43319-RS-ND |
| MANUFACTURER | Maxsa Innovations |
| DESCRIPTION | Battery Wall Sconce - Warm LED |
