This Product Selection Guide contains information to help select products in the Liquid Cooling, Heating category on DigiKey.com
Thermal Liquid Cooling comes in many forms heat exchanger, immersion chiller, recirculating chiller, recirculating chiller/heater, and cold plate with power ratings from 22W to 5000W. The flow rate ranges from 0.61GPM (2.3LPM) to 3.96GPM (15.0LPM) with a thermal resistance range of 0.0055°C/W @ 2.0 GPM to 0.084°C/W @ 1.5 GPM.
SelectionCharacteristics
Product Type: Provides a basic description of device function.
Power - Cooling: Indicates a device’s rated maximum cooling capacity, under manufacturer-defined test conditions.
Current: The maximum amount of current used during operation.
Voltage: Indicates the span over which a device’s operational supply voltage may be permitted to vary.
Flow Rate: Maximum fluid flow rate produced by devices with an integral pump.
Power Input: The nominal AC input power requirement for a temperature control unit.
Thermal Resistance @ GPM: The temperature difference between a cooled object and cooling fluid (usually water) per unit of heat transfer, given a fluid flow rate as indicated in GPM (Gallons Per Minute).
Fluid Capacity: Internal fluid holding capacity of a device.
Connection Type: Indicates the style of fittings provided for fluid flow connections.
Weight: Indicates the overall weight of the part.
Dimensions - Overall: Indicates the overall length, width, and height of the part.
Ratings: Minimum performance standards of the device, which are typically set by a third party.
Features: These are different capabilities or properties of the device such as an adjustable pump or auto restart.
ProductExamples
| MFR PART # | ATS-HE20-C2-R0 |
| DIGIKEY PART # | ATS2599-ND |
| MANUFACTURER | Advanced Thermal Solutions Inc. |
| DESCRIPTION | HEAT EXCHANGER WITH ONE 12V DC F |
| MFR PART # | ATS-TCP-1001 |
| DIGIKEY PART # | 684-ATS-TCP-1001-ND |
| DESCRIPTION | TUBED COLD PLATE |
| MFR PART # | 385736-001 |
| DIGIKEY PART # | 926-1098-ND |
| MANUFACTURER | Laird Thermal Systems, Inc. |
| DESCRIPTION | RECIRC CHILLER 2.9LPM 149W 4.7A |
MediaLinks
Videos
Liquid Cooling, Practical Guidelines to Design and Manufacture
Thermal Wizard for Liquid Cooling Applications
What is a Cold Plate and How Does it Work?
What is a Heat Exchanger
Product Training Modules
Liquid Cold Plate Technologies - Wakefield Thermal
Intro to Chill Series - Advanced Thermal Solutions
