This Product Selection Guide contains information to help select products in the Keystone Connector Accessories category on DigiKey.com
Keystone Accessories are supplementary items used with keystone connector types like adapters, backup plate/Herman Miller, blank faceplate, blank insert/module, cover, cover/icon, DIN rail adapter, ground clip to wire, housing, icon wheel, jack housing, label/designation strip, marker tag, terminal block, and terminal module in assorted colors.
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Color: The dominant color of the device.
Size / Dimension: The physical dimensions of the device. Typically height by width.
Material: Indicates the material composition of the device.
ProductExamples
| MFR PART # | SS-82200-001 |
| DIGIKEY PART # | 380-SS-82200-001-ND |
| MANUFACTURER | Stewart Connector |
| DESCRIPTION | Connector DIN Rail Adapter |
| MFR PART # | 9458510000 |
| DIGIKEY PART # | 1195-4003-ND |
| MANUFACTURER | HARTING |
| DESCRIPTION | Connector DIN Rail Adapter Gray |
| MFR PART # | CIPIW-C |
| DIGIKEY PART # | CIPIW-C-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Connector Cover, Icon White, Off |
| MFR PART # | N042E-WHMR |
| DIGIKEY PART # | 95-N042E-WHMR-ND |
| MANUFACTURER | Tripp Lite |
| DESCRIPTION | Connector Blank Faceplate Black |
| MFR PART # | 130910D1APLKE |
| DIGIKEY PART # | 1849-130910D1APLKE-ND |
| MANUFACTURER | METZ CONNECT USA Inc. |
| DESCRIPTION | Connector Extension Box White |
