This Product Selection Guide contains information to help select products in the Keystone Inserts category on DigiKey.com
Keystone Inserts are connectors of different styles or the same styles that snap into a wall plate to allow connection of an external cable into the wall run cables. The styles include audio, audio/video, banana, barrel/coaxial, coaxial/RF, d-sub, fiber optic, modular, USB, or video with exterior type being banana jack, binding post, BNC, D-Sub, DisplayPort, F-Type, HDMI, LC duplex, modular jack, MT-RJ, phone, RCA, RJ45, S-video, SC duplex/simplex, speaker post, ST simplex, USB, VF-45, or 3.5mm Stereo jack.
SelectionCharacteristics
Style: Indicates the type of connector.
Exterior Type (Adapter End): Identifies the connector that will be user-accessible in end use.
Interior Type (Adapter End): Indicates the connector present on the side of the insert intended for permanent connection.
Exterior Housing Material: Indicates the composition of the housing on the side of the insert intended for user-accessible connection.
Interior Housing Material: Indicates the composition of the housing on the side of the insert intended for permanent connection.
Exterior Housing Color: Indicates the color of the housing material that will be visible in end use.
Interior Housing Color: Indicates the color of the housing material on the side of the insert intended for permanent connection.
Exterior Contact Material: Indicates the base material from which the exterior (user-accessible in end use) contacts are formed.
Interior Contact Material: Indicates the contact base material on the side of the insert intended for permanent connection.
Exterior Contact Finish: Indicates the surface material on the contacts which are external/user accessible in end use.
Interior Contact Finish: Indicates the contact surface material on the side of the insert intended for permanent connection.
Ratings: Minimum performance standards of the device, which are typically set by a third party.
Specifications: This selection indicates the attributes which expound on a product’s abilities, but are not a standard attribute universal to this product family.
Features: These are different capabilities or properties of the device such as a dust cap, keyed, or shielded.
ProductExamples
MFR PART # | A-TA3534 |
DIGIKEY PART # | AE10093-ND |
MANUFACTURER | Assmann WSW Components |
DESCRIPTION | Insert Modular Jack 8p8c (RJ45, Ethernet) To Modular Jack 8p8c (RJ45, Ethernet) Black |
DATASHEET | Click Here |
MFR PART # | CJS5E88TGY |
DIGIKEY PART # | 298-12591-ND |
MANUFACTURER | Panduit Corp |
DESCRIPTION | Insert Modular Jack 8p8c (RJ45, Ethernet) To IDC, Pressdown, Punchdown Block Black |
MFR PART # | SS-82000-005 |
DIGIKEY PART # | 1847-1158-ND |
MANUFACTURER | Bel Inc. |
DESCRIPTION | Insert Modular Jack 8p8c (RJ45, Ethernet) To IDC, Pressdown, Punchdown Block |
