This Product Selection Guide contains information to help select products in the Power Supplies (Test, Bench) category on DigiKey.com
Power Supplies (Test, Bench) Equipment are designed to supply a variable amount of voltage/current to components for testing purposes. These power supplies have an output voltage ranging from 0 to 1000 VDC, and an output current range of 0 to 80 A, with the number of outputs being 1, 2, 3, or 4. The display types are analog, digital, LCD, LED, VFD, and no display.
SelectionCharacteristics
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Number of Outputs: Indicates how many outputs this device provides.
Voltage - Output: The maximum amount of voltage that can be output by the device.
Current - Output: The maximum amount of current that can be output by the device.
Display Type: Describes the user interface for indication.
Number of Characters: Indicates the number of digits displayed on a supply’s voltage and/or current meters.
Size / Dimension: The overall size of the main body of the device.
Features: These are different capabilities or properties of the device such as adjuatable or regulated.
Power (Watts): The maximum continuous output power a device is designed to produce.
ProductExamples
| MFR PART # | 9833B |
| DIGIKEY PART # | 22-9833B-ND |
| MANUFACTURER | B&K Precision |
| DESCRIPTION | 0 ~ 300VAC, 0 ~ 150VAC, 0 ~ ±424VDC Output Bench/Rack Mount (AC to AC +/- DC Offset) Power Supply LCD 10A, 20A, 10A Output Features Analog Input, GPIB, Harmonic Waveforms, LAN Interface, Memory, Software, USB Interface |
| MFR PART # | 867118-01 |
| DIGIKEY PART # | 2770-867118-01-ND |
| MANUFACTURER | NI |
| DESCRIPTION | 0 ~ 10VDC Output Bench (AC to DC) Power Supply 0 ~ 6A Output Features Expandable, US Power Cord |
| MFR PART # | T3PS60251P |
| DIGIKEY PART # | 1133-T3PS60251P-ND |
| MANUFACTURER | Teledyne LeCroy |
| DESCRIPTION | 60VDC Output Bench (AC to DC) Power Supply LCD 25A Output 1500W Features LAN, Programmable, Switching, USB Interface |
MediaLinks
Videos
1420 Power Supply
1415 Dual Output Power Supply from Global Specialties
Articles
Advanced Benchtop PSUs Offer Numerous Features
Blogs
Picking a Power Supply: What to do with a PSU?
DigiKey InstaLab
Product Training Modules
IT6900A Series Wide-Range Programmable DC Power Supply
TechForum
How to Obtain Positive and Negative Voltage Rails from a Single Output Power Supply
Guide to Selecting Industrial Component for Education
Benchtop Power Supply Ground Connections
